upgraydd »
https://forums.nicoclub.com/upgraydd-u119276.html
Mon May 18, 2009 3:31 pm
Goody, I did find burning around the ground you sent me to on the plug and the Module. So I need to replace the module and pump soon. I seen a module @ the yard but no pump. Also when I first connected the jump wire and turned the car on. It ran shortly and then stalled. I check the fuses and the 15amp had blown. So I replaced w/ a 20amp and it ran. I wonder if the battery I recently put in this car is big enough. The battery the car came w/ is bigger but has a small whole around the top (+) post. So I replaced the entire battery but didn't realize the battery I bought was smaller than the one taken out. Do you think this could be the cause of my problems. W/ the fuel pump and module? Thanx in advance.
