DriftingisLame »
https://forums.nicoclub.com/driftingislame-u25409.html
Sun Nov 28, 2010 2:07 pm
Hey guys, I've been working on a hardbody pickup for a little while and I've been having an issue with the idle stumbling and then dying mostly when hot.
When I got the car, another shop had replaced the Cap/rotor, plugs, fuel filter, and MAFS. One shop said it needed a motor and all 4 fuel injectors due to leaking injectors and low compression. Well I retested compression and found pretty consistant numbers around 165-170 psi across the board. When it got in it had a rich code, #3 injector wasnt clicking as consitantly as the others, so I replaced it. I took out the plugs and the o2 sensor that were covered in black soot. I cleaned the crap out of both of them and put them back in and everything got a lot better. Now I dont have a code but I still have a hot stalling issue.
Is there a common problem with these things that I should look into? I dont have a scan tool at the shop I'm working at so I cant check past codes. I am thinking about doing the o2 sensor next, the engine was run for a while being that rich and it could have fouled the o2.
Anyways, any helpful suggestions are appreciated.
Thanks!
-Max
