ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Sep 30, 2011 7:38 am
Your MIL will indicate left, right, pre or post depending on the quantity of O2 sensors. With an indication of a trouble code for a particular sensor the ECU which is by no means the brains of the system but more an indicator. As an indicator that ECU at that time indicated a possible problem. At that time it is not a trend, you must have at least 3x an indication with the same fault to indicate that a trend is happening.
Record all MIL faults and with time verification can be done. Sensors are a one time at a time indicators that have a threshold to hand out their indication. It is this threshold that is variable even if the threshold design is fixed. Why? These devices are massed produced and have a tolerance that varies just a little from one to the other. Two of the same sensors may be exact but very rare, they are close, very close and that closeness is the tolerance factor and this changes when that sensor is to be triggered but the ECU is built around these tolerances.
Even ECUs are not exact, close but not the same and it's this about the same that gives out a variable but close output.
When you have the output about the same at many times you may have a trend and it's the trend you need to work on.
So if you have the same trouble code reset and reappear three times then you may have a problem. If it is a heated O2 sensor the heat circuit or the actual O2 circuit may be at fault. Some sensors are not heated and they last longer but do become retarded in their action and thus create problems for a fast acting reacting ECU.
The engine always reacts to the ECU, the ECU reacts to the sensors, SENSORS react to their conditions, all this action and reaction takes time. Some reactions are handled with memory and only after a 2nd or 3rd reaction does the MIL come on.
You have a 1996 vehicle, that is the first year for the OBDII and there may be some gliches. The 96, 97, and 98 have far less real parameter used as compared to newer years. This may be a blessing more than a curse.
Repairing sensors is more work than replacing them, but they both require unplugging, letting the harness free, removing the sensor from its rusted bed. Then a trial and error of sprays to clean them then replacing that old sensor, hooking it back up and resetting the MIL and patience as you drive to see if it returns.
Time spent under a car is a PITA. Better to stay away from the bottom of the car, reset the MIL at leaSt 3 x to see if it's a trend then after the 3rd time buy a new sensor than go car diving once and fix the problem.
Or forget about it, tape up the MIL and reap the benefits of poor gas mileage, a rich engine and wait for a decoking process that will hinder cooling, render the knock sensors into play and destroy the catalyst and end up with at least $1500 in repair costs as compared to $150.
Although it always cost you, better the devil you know than the devil awaiting.
