Having misfire at cruise speeds. Above 70 and at idle runs great. Between aprox 40 to 65 it runs rough and misfires. Have changed the injectors, fuel filter, plugs, wires, new distributor (dealer recommended), checked timing. replaced egr valve, both O2 sensors. Also shifts a little rough if it helps. Any body have this problem and what did you do to get it corrected? Any help or suggestions would be greatly appreciated. Thanks
