djtomr941 »
https://forums.nicoclub.com/djtomr941-u11582.html
Fri Nov 28, 2003 6:56 pm
It was the Knock Sensor that went bad hence the idling problem... It detects something and changes the timing by 8 degrees.... If I would have driven on this for a period of time it could of done some damage.. All fixed now... thanks : )
WOW that thing was a pain to get to... now I just have to replace my Front Main Seal, Rear Main Seal.. Water Pump, Clutch... Should be a job... Plus I know there are 3 seals inside the cover by the timing chain that needs to be replaced. But I will just have someone do all of that.. Might as well have the timing chain and gears replaced too since it is all right there.....
Do you think this can be done without dropping the engine.???
