everything-you-need-to-know-about-the-z32-t508376.html that'll get you started and then some. Sadly seeing as you have a 96 you may be screwed for swaps since since there were very few OBD2 TTs and there aren't many tuners or available aftermarket options for the 96 short of full standalone. An OBD1 conversion could be done but then you may run into trouble with emissions testing (plus converting OBD2 vehicles to OBD1 is illegal as far as the EPA and NHTSA are concerned). Don't lose hope, all is not lost, you will just have to deal with a few hardships that most of us don't have. In a nutshell the only things that would be NA specific mods (assuming you will be keeping the shell, drivetrain, suspension, etc) are headers, injectors, ecu, testpipes/cats. Everything else can be swapped to a TT. Keep in mind that the radiator, AC condenser, and some of the PS and AC lines are NA or TT specific.
