maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Tue Mar 14, 2006 10:03 am
An injector squirts the gas into the cylinder in pulses. When it's stuck open, it will dump fuel into the cylinder constantly. When it's stuck closed, it will starve the cylinder for gas. I've never had it happen to me, but I would think that you would get raw gas out the tail pipe if it were stuck open.
You can't really fix the injector, you have to replace them.
The reason I suggested checking for codes, is that you should be getting some sort of code from running that rich.
