Yes, just adjust the idle a little higher. It's a pretty common issue. You should see the adjustmetn on the IACV (Idle air control valve) near the throttle body. I've had to do it a couple times on my mom's 2k maxima (that now has 234k miles on it), and actually my car is having the same problem, but I cannot adjust it without a consult II becuase my throttle is electronic.jltibbs wrote:sounds like a vacuum leak somewhere near the intake. you can adjust the idle right where your intake meets the intake manifold, see if that helps if you don't have a vacuum leak. if your fuel filter hasn't been changed recently, you might ought to do so. its right there on the firewall & should only take a few minutes to replace.
