96 Maxima on CL. Good deal?
c47v3770
Found a 96 Maxima on CL for $1500.
158K milesAutomaticBlack leather :PAC
Went to drive it and noticed that:
Check engine light is onBrakes squeak a bitThe Bose radio turns on but there's no audioThere's a small-to-medium dent by left front fender
The owner agreed to go with me to Autozone to get the engine light code/s read. So maybe he has nothing to hide?
Would you buy it if the code/s indicate nothing major?
Thanks for your time..
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Depending on the cause of the check engine light, it may be worth it. It will probably need a new radio, though. Squeaky brakes isn't necessarily a bad thing, but I'd pull the wheels off and have a look...if the pads are really worn, see if he'll throw in new ones.
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
drive the price down and get it. i got mine off ebay for $860 - the guy thought he was getting rid of a lemon and i got a great running car.
c47v3770
Thanks for the replies.
His original price was $1700 and he said he won't go lower than $1500 and I said "OK." But I guess it all depends on what the trouble code/s indicate.
I saw Bose radios for sale on ebay for around $100.
allensteiner, how did you get a maxima for $860?? What year is it??
Modified by c47v3770 at 12:03 AM 9/8/2009
allensteiner
it's a 95 gle and i won it on ebay if you lived closer you could pick up a 94 infiniti j30t for about $1000 instead of that max.
Modified by allensteiner at 8:54 AM 9/8/2009
c47v3770
Wow, I'm glad I took the car to Autozone.
Here are the trouble codes:
P0600 - ?P0325 - Knock sensor conditionP1447 - Control system purge flowP0400 - EGR valveP0500 - Speed sensor
Is the car worth buying?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
There are just too many problems with this car, based on your test drive as well as the DTC codes. P0600 indicates loss of communication between the ECM (Engine Control Module) and the A/T (Automatic Transmission) Control Unit which may be due to bad harness or control unit.
The problems above are indication of car neglect or even abuse. The suspension components are probably shot and the transmission is questionable.
In CA a car must pass emission inspection before it can be sold. I believe TX has a similar requirement but may not be as rigid as in CA.
c47v3770
Thanks so much for the reply.I will definitely pass on this one.
Sooo glad I got the codes read!
