Nonsmiley »
https://forums.nicoclub.com/nonsmiley-u222012.html
Sun Jun 30, 2013 1:48 pm
My son and I were outside when my 96 Maxima's horn came on. I looked over and the headlights were also on. I ran inside and got the keys and tried to lock/unlock the car using the remote to try to disable the alarm. Nothing changed. The horn wasn't intermittent like when the alarm sounds, but was on solidly. Also the headlights were on, although the switch inside was turned off. I tried disabling the alarm by turning the key to the unlock position and holding it, but to no avail. I finally opened the hood and disconnected the battery. An hour later or so I touched the cable to the terminal again and the horn began again. Not sure what has happened, car hasn't been driven today, no one was around or in the car or has touched it today. This began out of the blue with the car off and in park sitting in the driveway. I am not sure what the problem is, I think I will pull the fuse for the horn and reconnect the battery and see if it will start first and go from there. If anyone out there has any experience/theories on this let me know. I will try some more experiments to see if anything else is out of the ordinary. I would think it was just a problem with the horn or relay except for the headlights coming on too, it makes me think it might be a problem with the factory security system.
