96 maxima fuel pump
astrik
Car: 96 maxima gle
ok car shut off on me while at a stop light and i had one hell of a time pulling into the gas station next to me.
ever since i bought the car it has a had a hessitation to start. no cranking problem and i got an optima battery for it, but it just takes about 20 seconds before it actually fires up. mostly when first being driven for the day.
anyways im going to go ahead and replace the fuel pump.
does anyone know where i can find a diagram of the system and maybe any suggestions as to what it might be?
coolhand
Car: 1995 Nissan Maxima SE
If you remove the back seat there is a port that will allow you to remove it. Make sure it is not you MAF sensor that will cause a hessitation and no start.
astrik
Car: 96 maxima gle
you know where i can get maybe a picture or drawing of it? a guy at a mazda dealership told me it was outside of the tank behind the driver rear wheel.
astrik
Car: 96 maxima gle
and how can i test the maf? to make sure it is working properly.
maxhopper
Car: 02 Maxima SE 6spd
The guy at the Mazda dealership is full of poo. The fuel pump is accessed through a panel below the rear seat. On page EC-341, you will find a diagram that says "under the rear seat." http://www.nicoclub.com/FSM/maxima/1996/EC.pdf
Info on testing the MAF can be found starting on page EC-108 of the same section.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Is your check engine light (CEL) on? Any codes to check?
