96stillen_max »
https://forums.nicoclub.com/96stillen-max-u15316.html
Wed Jun 01, 2005 12:52 pm
ok well I got the new pipe on, along with a new CTS. When I started the car, it idled normally for about 2-3 seconds, then the idle slowly falls, until it hits 0 when the car starts to shake violently and then dies. If I try to tap the gas to keep it from dieing I can get the RPM to stay up for a little bit, but then it starts to kind of bog, and if I try to rev past like 4k it sounds like its getting starved, or like when your maf isnt hooked up, but my MAF is working. any ideas?
edit: I just went out and tried something else. I unplugged the MAF and staryted the car. it idled normally, of course I couldnt rev past like 3k, but without touching the gas, it was just fine. I plugged the MAF back in, and my problem began again, idleing for like 3seconds then dropping down to 0, and stalling. so I guess my MAF is bad which is kinda wierd cus I dont have a CEL, and 2 days ago before i started this, the MAF seamed to run fine.
