96 Max SE engine questions
Including IL, IN, KY, TN, MI, and OH
NISSANMAXIMA91
Car: 1996 Nissan Maxima SE
I have a 96 Max SE with the VQ30DE and auto transmission. i just had the transmission flushed, and i just checked it and it was low (I checked it with the motor on, and in neutral). but i was wondering if you check it with the engine off, or on and in neutral. And does anyone know how hard a transmission swap is on these cars? I also have a small leak coming from the oil pan. is there any certain hot spot this would come from? ex: sensor seal or pan seal etc. . . Also, do the timing chains ever need to be replaced?
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
Welcome to NICO man. You should really post this in the Nissan Online Mechanic section. You would get a much better response.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
NISSANMAXIMA91 wrote:I have a 96 Max SE with the VQ30DE and auto transmission. i just had the transmission flushed, and i just checked it and it was low (I checked it with the motor on, and in neutral). but i was wondering if you check it with the engine off, or on and in neutral. And does anyone know how hard a transmission swap is on these cars? I also have a small leak coming from the oil pan. is there any certain hot spot this would come from? ex: sensor seal or pan seal etc. . . Also, do the timing chains ever need to be replaced?
WElcome to NICO
You check the transmission fluid when it is fully warmed up and in park.....
NISSANMAXIMA91
is that a post thru NICO, or is that a totally different site.(i havent explored this site too much) and how would i go about doing this
elwesso
2007 BMW M Coupe
nissan online mechanic is right here:
zeroforum?id=23
NISSANMAXIMA91
thanks man
elwesso
2007 BMW M Coupe
Be sure to check our forum every so often for meets in the indy area.... We'd like to see you out there!!
Return to “Central Region”
