SLiguykyle »
https://forums.nicoclub.com/sliguykyle-u119660.html
Sat Nov 08, 2008 7:54 pm
okay, so i came home from work last week and found that my headlight on the right side was out (HID) i was initially hit with the wtf face, so i turned off the lights, and turned em back on (with the car in my driveway, still running) same thing, so i turned em off and turned the car off. and figured if i start the car back up and turn em on, maybe it'd work and if not it was going to need to be replaced. well, i went to turn the car back on and NOTHING.. just a *click* and that's it... the starter doesn't even attempt to start it, so i figure maybe the battery, so i checked the battery, checked connections, with good results, tried to jump start it in all hope that maybe it was low (since is was at 11.1v). same thing, not even attempting to start. so we put a scanner on it and came up with P0325 (knock sensor code) i figured WTF? how does a knock sensor prevent it from starting??? (if you know for a fact that this could be happening let me know) but i think it's the starter (not the solenoid kuz that works obviously or there would be no *click*) so i am going to take the starter out and take it to auto-zone and have them test it. but what does this have to do with the headlight? where can i get replacement HIDs? do starters really die like that outta nowhere? please, if you have any advice, let me know because my 240 begs me to drive it every time i pull up in my aunt's miata >.<..... this is my first post so far, and i'm still learning about my 240 (i know the basics, but this is kinda mind-boggling me)... help me get my 240 back on the road?
