96 KA24DE, will not start, after extreme cold
apollo500
Car: 1996 Nissan 240SX SE
I can hear the fuel pump start, injectors fire, has spark, the engine turns over, but the engine wont fire, I live in Chicago and we have been hit with temps of -5 and -20 with the wind chill, the car was parked outside, I started the car fine yesterday and today this happened, I have moved the car into my garage and heated it up to about 60 degrees and after 6 hours the problem still persists, and help would be appreciated
apollo500
UPDATE: i went into my garage, the engine turned over 6 times and started up, it ran for 30 mins and i turned off and turned it back on several times and there is nothing wrong, anyone knows what could have been wrong?
Modified by apollo500 at 7:34 AM 1/21/2008
VeLiduS
Car: 92 240sx
Im no expert but im south of chicago and have been having trouble starting my car in the cold . it would turn over fire and start and immediatly die . unless i hit the gas at the right time to be able to force it to run hard to warm up ... well my and my bro got to looking around and the water temp sensor had a broken wire . fixed that and had no more problems starting . obviously yer prob sounds like a cold start issue so maybe check that sensor out . sensor was on or very near (maybe on head ) the intake manifold. hope this can help ya . good luck!
BoostedNismoNJ
Car: 1991 240sx
Battery could have frozen
apollo500
BoostedNismoNJ wrote:Battery could have frozen
im fairly sure that the battery was ok as i replaced the battery with another one that i took out of my brothers mustang gt, while i was checking what was wrong, and the problem still persisted
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Wasn't it also recently warm out there? How much fuel have you kept in the tank? A rapid change from warm to cold will introduce condensation in a nearly empty tank. Try some drygas next time it's running.
apollo500
it was warm but it got cold over a week, also i have topped off the gas tank 2 days before the freeze came with 93 octane gasoline
applespeed
Car: 1992 nissan jalopy S13
i kinda have the same problem too. make sure that the inside of your trunk and in the spare tire well is dry. also try covering the top of the fuel pump cover with a dry towel for insulation. never have the same problem again.
