Shift__BODOM wrote:1) ECU and wiring harness stays, why should i use the intake and exhaust manifolds from my '93? is there a gain to this?
2) arent the '96 cams also a little more mild than the '93's?
1) Becuase then all the sensors plug right in, instead of swapping them one by one onto the '96 intake manifold...
The sensors are quite similar between S13 and S14, but the plugs are different on most of them.
So there's no power gain, except it saves time and energy.
2) Yes, you need to swap cams for better power.
- Brian
