480sx »
https://forums.nicoclub.com/480sx-u50548.html
Sat Mar 10, 2007 2:34 pm
Alright i just broke the crap out of my crankshaft pulley by following the FSM directions and picture. Broke it TWICE, real good, a large piece of the pulley is still connected to my crank. My question is, how are you supposed to remove it?
I took a 3 legged pulley remover and put it on the second pulley section and tightened it up. The first break was on the lip of the second pulley section. After sitting there depressed for a while i did the same thing again, and made sure the feet had a good bite on the pulley. I also let the pulley soak in PB blaster for a while with tension on it. I thought i had it taken off smoothly, however when it came off i realized that the whole back of the pulley was still attached to the crank.
The FSM picture in 'Timing chain removal' shows exactly what i did. I placed the head of the tensioner on the crankshaft bolt, and tightened.
Did i have to remove that bolt or something? Please get back to me im in a pretty foul mood because to me all i did was follow the FSM and i got the shaft.
