grounds are fine all checked and re tightened i have no clue what relays to use or pull to check so i swapped them all around to see. ecu is fine it ran my friends car perfect.
the harness next to my ecu i have the the ecu hooked up the relay the bigger plug that goes to the cab wall and the plug that leads to the rear now there is a random plug that goes nowhere that doesnt plug in to anything. i need my car running asap i dunno what else to look for where are all the important relays so i can replace them just incase.
i replaced the harness the ecu plugs rotor cap wires engine and trans are brand new rebuilt 3k just rebuilding im starting to get a bit mad. plz someone just help me out plz......
