nuts510 »
https://forums.nicoclub.com/nuts510-u34687.html
Mon Nov 09, 2009 2:17 pm
To make it work right used the intake manifold from the car you will also need the switchover the 2 control valves , they bolt to the back of the head be sure not to get the vacuum hoses confused. You will also need to change out your distributor.and to be quite honest while you have the distributor out if it were my car I would pull the upper front cover off and do the upgrade that Nissan has for the timing chain basically all you're doing is removing the too small timing chain guides that bolt to the head but be sure that leaves the timing chain tensioner in place, not only will this make your car quieter I have seen several instances where there guides broke off and did some serious damage to the motor
