96 J30 Passenger side Headlights
sugarsugar11
Car: 1996 Infiniti J30
Both the low and high beams work sometimes, then sometimes not. I will turn them on before I start driving at night, and not even a few feet from parked, the lights are out. And I can not get them to come on again, until after I park the car again, turn the ignition off, and turn them on again after an hour or so. It seems very much like a wire(s) that's loose, but I looked as best I can, and I don't see any loose or chafed wires. HELP!!!
driverdriver
Car: NICO's longtime resident Canuck!!!
The bulbs, that your using are normal 55 watt ones, right?
You could have a relay issue from someone using improper wattage bulbs or headlight harness issue.
yodawill2000
Car: 94 Infiniti J30
http://www.fuzzycats.com/docs/headlight_relay.pdf
Quite common on the J's to have relay issue's. :bigthumb:
