I
cobraball wrote:According to my mechanic and the front-end vibration, the front struts of my '96 J30 should be replaced. (110K miles) Yes the wheels/tire are balanced.
Will replacing just the front strut cartridges most likely cure the problem? Any way to evaluate the existing strut assembly to see if it is just the cartridges or the whole $$$ front strut assembly?
Thanks for the response.
I just rebuilt my entire front suspension (struts, upper strut mounts, springs, tension rod bushings, rack, outer tie rods, stabilizer bar links & lower control arms) & I had the same problem starting at @65 mph. The culprit was the lower ball joints (totally shot) which you have to buy the entire lower control arm @ $190 each. I am at 113,000 miles, 97 J30.
