96 J30 - Clunking in front right.
96J30
Car: 1996 Infiniti J30
I've got a 1996 J30 with about 172k miles on it.When turning the wheel to the right at very low speed (i.e. backing out of the driveway) there is a clunk/pop sound from the front right wheel well.The sound also occurs at most speeds when the brakes are applied. I can press the brakes, let off and press them again, and the sound will happen each time the brakes are pressed.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
So, like the sticky above requests, how about a little maintenance history?
If the same suspension design as the Z32 and G50, I would look at tension rod bushings and upper llinks.
96J30
Sorry about lack of maintenance history, I've only had the car a few weeks.I have the full service history, just not with me (Primarily online at school, no internet at home)
Mr.Twister
Car: 96 Infiniti I30
Sounds strut related.. my 240 did the same thing. Pop your hood and rock the car back and forth. If you hear the popping sound then most likely its a bad strut.
96J30
Addition:Front rotors are a little warped, so slight vibration under light braking. The clunking is in sync with the rotors (ie, it clunks/ticks at the same rate as the vibration from the rotors)
