ive just completed the changeover from automatic to 5 speed...
the problem is the lines to the clutch came off of a non ABS maxima and my I30 is ABS...
the lines wont fit because the ABS unit is in the way...
i tried to run a direct line from the resevoir to the slave line but it didnt work...
im frustrated now that i am at the final stage of this conversion and having trouble with the clutch line...
i am assuming the transmission i got is a non locking but is there a way i can identify the transmission i got to be sure it is a non locking 5 speed transmission?
also need to figure out the clutch safety wire and reverse wiring...
ive lowered it with new eibach springs and putting on some konig imagine 18 in wheels...anyone know the largest size tires i can run without rub? i found some 235 50 tires but not sure if it will rub...
thanks for any and all info or advice in advance!!!
