96 I30 P0600 & P0500 ?
g35wannabe
Car: 03 g35 sedan
the p0500 is to check the vss and its good but the problem is the p0600 is a comms error between the ecm and tcm. it says to check resistance between the ecm wires 65,66,73,74 & 77 to tcm wires 47, 38, 10, 11 & 12. well i have all the wires on the tcm side but ecm wires 73 & 74 are missing??? it doesn't appear as theres been any tampering so i tried to see if maybe there were moved in the ecm plug? nope? its not been moved so where is it? my speedo works fine and trany shifts perfect. i just have a abs & check engine lights??? maryland state inspection won't pass with abs light. check engine light doesn't mater. any help would be great! thanks
MaximA32
Are you getting the correct power to all the right places when you checked input to the TCM?
g35wannabe
Car: 03 g35 sedan
p0600 just has you check continuity not voltage. but my question is, is the procedure wrong ? i am missing 2 of the 5 wires? So i thought maybe they are pinned somewhere else in the ecu plug but i was not able to find it?
