i30krab »
https://forums.nicoclub.com/i30krab-u398.html
Thu Aug 22, 2002 6:43 pm
I was driving today and the transmission was shifting just fine and the temp was about 175 degrees. Then the transmission wouldn't shift out of 3rd gear. Its stuck in 3rd, no overdrive, 2nd, or 1st but the reverse works. This happened all of a sudden, no warning and the transmission temp went up 25 degrees Is it possible a wire or line or connection came loose or does it have to be inside the transmission or possibly a transmission computer problem??
By the way, there is no check engine light.
