The blower assembly and evaporator are behind the glove compartment. The cost of repairing the problems depends on whether you are going to replace a component or not and who is providing the labor. Shop labor rate is @ $75/hour, more if you take it to a dealer. A fan-motor assembly from IoS. [url=
http://www.infinitipartsusa.com]
http://www.infinitipartsusa.com is @ $150.
The Fan Control Amp (resistor) also referred as Module ASM by Nissan/Infiniti can also cause blower issues. Depending on the model year, the price could be $57 (27761-2Y000) or $98 (27761-70T03).
Better download a copy of FSM (Factory Service Manual), specifically "HA' chapter (Heating and Airconditioning). This will give you a better idea of system operation, component location and diagnostics.
Rod
Modified by loystock at 1:14 PM 6/24/2009
