malibumarlin wrote:Well i've done a new timing chain on my 1985 nissan hardbody 2 times. When i finally traded it in, I had 375,000 miles on it.
If you get the timing chain on incorrectly, meaning the piston isn't at TDC on the reinstall, you will experience exactly what you describe: won't idle below 3000 rpm or so. this is because the timing is off, and the valves are banging into the pistons.
Chances are that you have now bent a valve. I speak from experience on this one. The first timing chain replacement, i decided to have the head rebuilt. I bolted everything back on, thought i had TDC. Fired up the engine and just like you said, it would run at 3000 rpm, but stall when the not reving it - wouldn't idle.
I had to pull everything apart, and because of the mistimed engine, i bent a valve. I was lucky i didn't crack the piston. You should have seen the valve.
Your safest bet is to pull it all apart again and redo it... that is if the problem persists. And at this point, you might want to consider pulling the head off and check the valves, and your pistons too.
TDC is best determined by the #1 piston being at it highest point on the stroke. You can pull out the #1 spark plug and insert something in there and watch it rise and fall as you manually turn the crank a full 4 piston revolution. And then you have to determine TDC on the valve head because it too has it's sequence of positions. Then you have to get your distributor on TDC when you insert it back into the block, because it's worm gear has to mesh up inside as well as stay on the TDC position for the rotor to match up with the distributor's #1 mark. All 3 have to be at TDC.
So you see now, how important it is that all 3 (piston, valve head and rotor) all need to be properly aligned at the TDC of the #1 psiton. Otherwise you'll never get the engine right. And again, i can't stress how important it is now that you have been running the engine, to do the right thing, no matter how inconvenient and painful it may be. But pull it all apart again and at this point the valve head too and check it all out. A head rebuild is well worth the money. NAPA did a great job on mine and the price was right. Just pull the head off and take it in somewhere. You'll need a new gasket set and all that good stuff too. You'd be wise to change out the water pump too, seeing that you have it all pulled apart. Soon after my rebuild, the radiator went. So check yours out while its off. May as well do as much now, so you don't have to mess around taking it all apart again later.
Also be sure to clean all your thread holes for the timing cover and such so that you get proper torque readings. A new set of bolts is also a good idea, because chances are you'll snap a few heads off un/re-torquing them all over again. And trust me, that's a real pain in the butt. A tap and die set is a nice thing to have to clean and retap thread holes.
Hope this helps. If you're burned out from the process, take a break, and come back to it with a rested mind and back. Patience is key. Frustration is guaranteed. Ever read the book Zen and the Art of Motorcycle Maintenance?
First, thanks so much for taking the time to write in so much detail. It does mean a lot because I've become very frustrated at this point...partly because the truck was running fine (other than the slapping noise) and has ALWAYS ran great and is ALWAYS dependable.....until I decided to dork around with it. So here I am.....
so a few questions if you wouldn't mind:
1. would the evap issues I described cause my "won't idle issues"?
2. the BBs getting free and winding up on the floor of my garage; do those come out of the charcoal box? could they be "clogging" something up?
3. Say it isn't the evap codes and it is the timing....once I break everything back down, with timing chain exposed, will I need to slip the chain off set everything as you described above and put said chain back on?
I promise I read every "setting top dead center" thread I could find on here and other forums and I thought I got it right the first time, but I am a novice and s**t happens.
Again thanks for the advice and the direction. I'm going to try and make some headway Saturday morning before the wife breaks out the Honey-do list.
