96 hardbody 4x4 not firing
struckinc
Car: 93 hatch.stock.well mostly anyway-SOLD
97 kouki-stock
12 sentra sr-wifes new car
97 maxima-wifes car-SOLD
02 maxima se- daily
1936 austin 10/4 lichfield
ok hers the deal...my truck was flooded during the hurricane...i got it running again after replacing the ecu, all fluids, spark plugs, dist cap, rotor, wires...it ran ok but wouldnt rev up very high..kept going into loop mode..i traced it to a bad air flow meter..while i was waiting for the meter to come in i pulled the gas tank..replaced fuel pump and sock..put everything back and the truck started and revved up very well for about 3 min. then it died and now i am getting fuel but no fire..i took the dist apart and replaced the ignition coil and cam position sensor with a part from the junk yard because i am pulling code 11 from the dtc's..along with a purge solenoid valve code-which i know i left unplugged after taking tank out--and a front o2 sensor code--which i think i caused when i unplugged the harness to clean connectors...i dont see both cam sensors and coils being bad and i have the service manual so i have traced most of the circuits in the trouble tree and everything looked ok..i am getting an ohmmeter tomorrow so i will be able to check resistance etc.. better tomorrow..but is there any direction you can point me in that would save alot of pinout testing? the starter was kinda acting up but now seems fine..would that cause a spin but no fire situation?
struckinc
97 kouki-stock
02 maxima se- daily
sorry so long i just like to give as much detail as i can to help..btw it is a 4cyl 4x4
struckinc
97 kouki-stock
02 maxima se- daily
just an update..i followed the fsm and checked continuity and voltage all the way down the flow chart..everything checked out fine..the only thing i cant check is the resistor that is supposed to be on the dr side inner fender somewhere...i cant find it..ive checked the wiring diagram, component location chart, and it all says it should be there..i dont see it..i have talked to several nissan people and they say that part goes out alot and causes a no start problem but i just can find it..any suggestions where it can be?
struckinc
97 kouki-stock
02 maxima se- daily
anyone? this thing is driving me crazy...and i cant find this resistor..is it located somewhere different ina 4x4?
