96Qowner »
https://forums.nicoclub.com/96qowner-u19561.html
Wed Jan 03, 2007 7:30 am
Yeah, just swap in a used one and be done with it. Both you and the wife will be relieved. I know it drove mine crazy. It's just not worth futzing with for very long. The internal connections go bad, and no amount of cleaning will help that.
It also occurred to me that the tech may have disturbed the MAF connection when he did that work. It wouldn't hurt to wiggle the connector while the car is running, and see if the idle jumps around. If so, pull the connector, clean it up real good, spread some dielectric grease on it and snap it back together. Might be the whole problem.
Modified by 96Qowner at 11:57 AM 1/3/2007
