96 altima with a 98-01 ka24de swap?
General discussion area for the U13-chassis Altima
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
I am a 240sx guy, but I had someone ask me if I could swap in a newer altima ka24de into their 96 altima. Can't find any material on this so I was wondering if anyone new in the Altima community. Thanks guys
-Steve
blubird
yes it can be done I currently have a 2k motor in my 93 you have to swap over the 96 intake manifold as well as some minor orther stuff to make it work. check out http://www.nissanclub.com/forums about 5 other members I know of there have done it.
AltiNate
Car: white 2000 Altima SE auto
FYI it's the 00-01 motor that you want. The 98-99 KA is the same as what he already has. The 00-01 has 155hp, 156lb-ft, and the 93-99 has 150hp, 154lb-ft. The difference isn't anything a small amount of modding couldn't make up for. All Altima KAs are essentially the same and can be swapped in to and out of any 1st and 2nd gen. The only diffence they have that I can remember is reshaped valve covers.
Importroller
Car: G35 and 07 Altima 3.5 6spd
AltiNate wrote:FYI it's the 00-01 motor that you want. The 98-99 KA is the same as what he already has. The 00-01 has 155hp, 156lb-ft, and the 93-99 has 150hp, 154lb-ft. The difference isn't anything a small amount of modding couldn't make up for. All Altima KAs are essentially the same and can be swapped in to and out of any 1st and 2nd gen. The only diffence they have that I can remember is reshaped valve covers.
the only real difference is the different manifold and sensors. its nto a hard task to switch them over. my OBDI 94 has a 95.5 OBDII engine and a 97 OBDII trans. its very easy to switch the parts over when the motors arent in the car. i did mine in my old driveway in a weekend with very little help
finedtuned240sx
I have couple of question I have a 95 nissan altima automatic its been sitting in my garage for couple of months. what parts do I need to converted into a 5spd?
Modified by finedtuned240sx at 8:59 PM 11/9/2005
1jz240sx
hey whats going on, do you still have that rhd rack.. call me @ 9088214001 or email me @ [email protected]... asap
Return to “1st Generation Altima Sedan (1993-1997)”
