MarkEmark wrote:It'd be a good turbo if KA's revved up to 9000 rpm
What you think the red line could be with this?
-Stainless Steel Black Nitrided INTAKE and Stainless Steel Black Nitrided EXHAUST valves-Ka24de High-Performance DUAL Valve Springs and Titanium retainers-Port & polish head
is there some kind of roller rockers for the ka or would the O.E. ones do? Bottom End-Shorter Forged Con/Rods-Ballanced Crank-Ross 8.5:1CR Forged Pistons
also does anyone think this might be over kill for a Garrett T3/60-1 W/.48 A/R Turbine?
COMPRESSOR SPECS:T04S .70 A/R housing 60-1 TRIM wheelTURBINE SPECS:T3 .48 A/R housingHIGH FLOW 76 TRIM stg 3 wheel oil lubricated centersection.
COMES STANDARD WITH 360 DEGREE THRUST BEARING!!(i dont know what a THRUST bearing is )
