96 4wd XE PU needs work
zeke
Car: 96 Nissan 4wd xe king cab
Am about to replace the drive line (propeller shaft) support. Rubber all gone. Anyone done this and have any tips before I dive in?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Commonly referred to as the carrier bearing. Pretty straight forward repair.
something to consider would be eliminating it and having a driveshaft shop build you a single piece driveshaft. It's possible a 2001-2004 OEM king cab or short crew DS would bolt in as well.
Dattebayo
I have seen alot of people put the thing in backwards, so take note of the direction of the metal support that it fits in.
I would only do the single piece shaft if you have lots of money or time, matching up parts from other vehicles can be a btich and even junkyards can charge lots for a shaft.
PapaSmurf2k3
Site Admin
Moved to the hardbody section.
centralcoaster33
Car: 1997 Nissan 240SX #5
When you are removing the shaft, please remember to make match marks so that when you bolt it back together, the same bolts line up with the same holes. I find white out works well for this. The shafts are balanced together (this is my understanding) and if you put them back together with one rotated 180 degrees from where it was mated with the other, you'll have vibration problems. It wouldn't hurt to match mark at the diff as well if you're taking that end of also. I'm currently doing this on my 240sx, except I am replacing the entire drive shaft. Also, pay attention when taking off the carrier bearing, I don't recall if there is a front or back to it, but if so, you'll want to keep track of that. Good luck and let us know how it goes!
