Tixmaster »
https://forums.nicoclub.com/tixmaster-u128136.html
Wed Mar 18, 2009 8:10 am
hi guys. finally got this car almost 100%. checked all the fuses with a test light under hte hood and in the driver kick panel. every thing works on the car except when you turn the lights on the rear lights dont come on and the turn signal works never. rear brakelights do work. when you turn the parking lights on the front corners do light up. there is no clicking when you turn the signal stalk up or down. i went and unplugged the rear lighting harness and when you turn the headlights on it gets no signal, and same with turn signal so i know its not the bulbs,. but hte rear harness gets signal when you press down the brakes. any clues guys? is there a specific relay i should be changing?
