SCKA24E wrote:any one. there has to be some knowledge on this
From my research and similar problem your Intake Air temperature sensor present on early SOHC and 95 and up DOHC motors will cause the engine to idle like **** once warm and dump fuel aka run rich if the sensor is broken or wires faulty (my wires ripped and threw a CEL instantly). At first I thought it was my idle air control valve (IACV) but after replacing all gaskets, new hoses the iacv and aac on the intake manifold side it seems to point to that because problem still exists. I will replace my IAT and ill tell you whats up.
