walperstyle »
https://forums.nicoclub.com/walperstyle-u38250.html
Fri Jul 13, 2012 11:29 am
come on guys teach him how to isolate the problem first
When its bucking and running bad, if it does this at an Idle, try un-plugging a spark lead (wire). See if the problem gets worse, or A LOT WORSE.
why? This might help you locate what cylinder is having the issue. You unplug one, listen for a moment, feel the engine see if anything changes for better or worse. (it still can be all of them, so don't feel bad if you don't get any different results). You can kinda judge where a problem is happening by the reactions of the engine.
Try swapping out injectors, or at the minimum, clean them. (you can search google on how to do this)
Take off your fuel lines, and make sure there is no debris. Air hose works great for blowing crap out.
Check your fuel pump sock. AKA, its in the gas can, pull your fuel pump and take a look for any rust, or bad gas. I once had some 'orange' looking junk from a gas station once. I was pissed, had to clean out a carb for 2 hours the next day... as well as the gas tank.
anyways, that should help you get started. The problem could also be a bad ground wire, or lead wire, or something along those lines. Try shaking wires in the engine bay to see if anything gets better.
