Twilight sentra tuner »
https://forums.nicoclub.com/twilight-sentra-tuner-u65262.html
Mon Dec 03, 2007 1:31 pm
how long does the light stay on? need a little more info.
if it comes on and stays on for a little bit, thats probably normal when the motor is cold. because when the motor is cold, all the oil in the system is in the oil pan. when ur motor starts up, it starts pumping oil through the system. the sensors or gauges pick up the oil pressure eventually. but when they do the light should go off.
