During the pad/rotor change, I noticed that the passenger side rear caliper had a bad seal and was very hard to turn down; the friend who was helping me out thought it was in need of a rebuild, but we didn't have the time or parts to do that at the time. Could the caliper be stuck and be causing this problem? If not, does anyone have any ideas?
On the advice of the same friend, I had the differential fluid changed, which seems to have had no effect on the problem. The mechanic who did the deed didn't notice anything odd with the differential or the used fluid.
As per the sticky post, here's the relevant info on the car:1996 Nissan 240SX SE (open differential, stock)Location: Memphis, TNMileage: 95kRelevant Component Info: Rear brake pads and rotors changed one month ago, rear calipers rebuilt once at 50k (according to the prior owner; this hasn't been verified), rear differential fluid changed (for what might very well have been the first time) in the last week.Transmission: 5 speed manual, stock
I have another tricky question about fuel injection fuses blowing on a 240SX that another friend of mine owns, but that's for later once I collect all the relevant infomation.
EDIT: This problem doesn't seem to affect driveability in any other gear, and I don't have any problems shifting gears; the car shifts very smoothly and doesn't grind while going forward. I figured people might ask about that, so there you go.
