96 240sx converting to stick shift
fresno240sx
hey
everyone i got a question i planning to convert my to manul do i have to remove the dashboard and remove the wire that connect to the ecu or not?? is it hard or easy let me know thanks..
fresno240sx
the transmission is from a 95 240sx and it obd 11 so it perfect fit on my 96 240?? correct anyone hlep me thanks..
s14_240sx
Car: 96 240sx Zenki
no u dont have to do anything to the ecu, but u will have to drop the steering column and go into the footwell to install the pedals (clutch and new brake). Yea the transmission will fit perfect, but i believe u will have to connect an sac sensor near the front of the belhousing if its is from an s14.
nightkid86
Car: 97 S14 SE
you will have to take out the center console to access the shifter. If you use the automatic transmission harness (with a 5 speed ecu - an auto ecu can work but you will get major check engine light) you have to splice a wire together that is coming out of the back of the ECU in that bundle for the neutral position switch. So you will need a new ECU, and you will have to splice a wire.
The transmission will fit fine, however you may have to drill a hole to fit the magnetized crank angle sensor (CAS). Some OBDI transmissions do not have the hole for the CAS, but OBDII cars need it. I have a stickied writeup of everything you have to do at the top of the technical section. It should answer all your questions.
Is it easy or hard? Do it and then tell me what you think. Personally I think it's easy and straightforward but it is a major pain in the *** to do.
nightkid86
Car: 97 S14 SE
fresno240sx
will i need info so i know how exactly to do on the manul conversion. But i have a project car i want to fit also is a 95 240sx se will the 94 transmission fit on it as well cause the car is obd 11 the 95 just wondering..
nightkid86
Car: 97 S14 SE
I have posted the link. it has step by step what to do and plenty of pictures.
The s13 trannies will fit but are OBDI. Also a 94 transmission is automatic, so I dont know.
my writeup and the links in my writeup should cover everything you need. if you have any more questions feel free to IM me. my Screen name and email are listed in the writeup
s14_240sx
Car: 96 240sx Zenki
nightkid86 wrote:an auto ecu can work but you will get major check engine light) you have to splice a wire together that is coming out of the back of the ECU in that bundle for the neutral position switch. So you will need a new ECU, and you will have to splice a wire.
Its funny, i did the swap in my 96 and the check engine light didnt go on? I also used an s13 transmission and the car still runs perfect without the CAS, and i didnt have to mess with the ecu (plus auto ecu's dont have speed limiters )
Is my car supposed to be throwin codes?
nightkid86
Car: 97 S14 SE
yeah, mine with the auto ECU hooked up threw at least 6 codes. They all went away when I put in the 5 speed.
kevinarich
Car: S14
i have never been under my S14. I just bought it a few days ago. I want to know if I can plug in the manual transmission harness in place of the auto one. Is this how it works? Im getting anything that is different off of a wrecked S14. Want to make it as complete and as factory as possible with out getting crazy.
nightkid86
Car: 97 S14 SE
the manual transmission harness will be plug and play, but in my opinion it is easier to just wire the auto transmission harness to work.
fresno240sx
ok thanks you guys for the info...
fresno240sx
cool then thanks for the info..
fresno240sx
thanks alot everyone..
fresno240sx
240sx is a great car..
fresno240sx
ok...
boznuttz
Car: MS13
Postwhorin' it up.
fresno240sx
thanks fool..
180fan
Car: 89 fastback
ha ha ha. I'll let this post whoring continue since it seems to be relevant to many peoples interests...
