sidewards »
https://forums.nicoclub.com/sidewards-u33437.html
Mon Oct 24, 2005 4:22 pm
I own a 96 240sx with the stock ka w/ 82k. The power steering pump is making a turbo like whine. The reservoir is filled to the proper level. I've notice that a small amount of fluid has wetted the connection where the metal line is crimped on to the big rubber hose. It must be a slow leak because the reservoir usually doesn't need fluid. Occasionally the pump or belt will squeal during slow speed turning. The pump works fine for now but I am pretty anal about my car and also would like to prevent a destroyed belt from rapping around my fan. thanks.
