This is my first time posting so here goes. One morning I get up and my S14 decides not to start. I have a megan racing fpr and gauge installed so the first thing I notice is that I have no fuel pressure. I check the fuses they're fine, check the relay it's fine, jumped the pump from the battery it works perfect. while I was doing all this I decided to poke around at some other things. I found out it's also not getting any spark. I went over all the fuses and checked/cleaned up all the grounds. I suspect the ecu but everything on the car works the way it should except the fuel and spark. Another problem is I can't get a hold of a ecu to test out. I'm hoping someone knows something that could be the problem or something else to test.
The last thing I did to my car was rip out the egr s*** and block it off at the intake manifold. The fitting for the egr tube to the header was rusted really bad I had no choice but to cut it to install my new header (which I had to waste $ on cause the retard who had the car before me made his own custom exhaust that broke on the highway and since they cut and re-welded the header my new cat and catback wouldn't fit, I hate retarded people) I don't think that really has anything to do with my problem seeing as how my car worked for the next 3 days. Idk please help, thanks.
