95Q45 w/factory Bose - MP3 hardwire questions
Post all your Nissan electronics, car audio and stereo questions here!
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
_i have a belkin fm transmitter (sucks)tape deck adaptor much betteri want to hard wire a plug for my MP3 player, was wondering if i could a/b switch the input for thee cd changer and plug in like thatany ideas?thanks
Modified by jamesmost at 10:46 AM 7/20/2005
onosqv
Car: '92 240sx Vert
Um, I think the best & easiest you can do is if your head unit supports something like AUX or something, get a stereo jack -> rca adaptor and hook it up that way to the AUX in on the head unit. Only thing is you have to control the song, etc via your mp3 player.
Unless you have an ipod, then you can get a head unit that has ipod support.
Hope that helped.
jamesmost
stock Bose head unit no aux input, notl ooking to change the head unit either
Rex
Car: None
jamesmost wrote:stock Bose head unit no aux input, notl ooking to change the head unit either
I know yours is a 95, but check out the "compatability" notes at the bottom http://www.discountcarstereo.c...D=610
Also, there was a Maxima guy that built one and would sell them. He was unwilling to provide a diagram of "how to", but since he's not offering them for sale anymore, he might.
Try a few google searches for - (Nissan, infiniti) Bose Aux in
jamesmost
i have searched all of these products and none for my system i do not know if i have the 12 pin but i would assume not
Rex
Car: None
jamesmost wrote:i have searched all of these products and none for my system i do not know if i have the 12 pin but i would assume not
In the trunk, where the CD changer would plug in (assuming you don't have one) is the plug, I think it's a 16 pin connector, but 2 each on the ends are not used.
It may be worth swapping in a newer Bose with in dash CD, that these adapters are designed for??
I go on a stretch ever now and again to make this work. I feel like I'm about to again ...
jamesmost
rexi have a full reconditioned changer from sony in the trunk which i still useDoes 16 minus 4 = 12 ??
Modified by jamesmost at 10:00 PM 7/21/2005
Rex
Car: None
I'm going to be out of town for a few days, but will do some mroe research on this. I "think" a newer Inf/Nis Bose in Dash CD player can run your CD changer and with the right switching device allow you to use both the changer and AuxIn.
jamesmost
good thinking please let me know, i would gladly swap out head unit and buw the $100 switch.what about my idea of splicing a switch on the cd changer harness
Rex
Car: None
I think it really depends on your skills and being able to get ahold of the wiring specs??
jamesmost
my skills are adequate - wireing diagram may be in the fsm -time is another question -is it the same dimensions as the '95 ?I realy want the esay fix though
Rex
Car: None
WOW, look what just showed up
zerothread?id=128200
jamesmost
tha
Rex wrote:WOW, look what just showed up
that is what i need for 12 pin
