911/Q45 wrote:That little clip is part of the shim hardware, not a sensor.
As I stated before, these "TWO" little clips came in the sealed package with the brake pads from Joe.
The hardware KIT-FR (41080-60U28) includes the following:41083-60U04 SPR-RET, Pad (4)41083-60U05 SPR-RET, Pad (4)41084-60U00 SHIM (4)41085-60U02 SHIM COVER Inner (2)41085-60U01 SHIM COVER Outer (2)41003-03P25 GREASE (2.5g) (2)
Not mention of the TWO clips (sensors) in the kit.
Even if as you said, they are part of the hardware kit, where do they fit?
Thank you for your input. I'll call Joe on Monday and I'm pretty sure that he'll have an answer for the benefit of all of us.
