elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed Dec 08, 2010 6:49 pm
just so you know, 7 ft lbs is roughly equivalent to "snug" with a 1/4 in drive socket.. The point of the torque pattern is to get everything seated before final torque because the valve covers are big and aluminum, so its possible to crack them..
I don't konw of any torque wrench that actually reads that low in ft-lbs, most of them are in in-lbs for 3/8 drive or 1/4 drive... last time I did the valve covers on a friend's car I followed the pattern in the FSM, but didnt pay much attention to the torque.... Its important to note that there is a TOO tight because those little studs are EASY to break. And like Brian said, if you're missing some of the hardware like the metal/rubber washers, your torque will be off because theres not much thread sticking out above the studs.
