95Q subframe bushings and diff mounts
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
Wes just turned me on to a thread for the rear sub frame bushings same for 90-96 300z energy suspension part #7.4102what about the differential mount is it the same for the Q as well??
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
Yes, the differential bushings will also fit.
I have the poly subframe bushings and the poly rear differential bushings, all from Energy Suspension. The rest of the bushings have been replaced with Nismo rubber bushings for a 300zx.
I tried poly bushings in the control arms, but they were noisy and eventually failed. But the subframe bushings and the rear diff. mount bushings have held up for almost 2 years now. So, I will recommend them.
-sijoko
jamesmost
they should last longer than stock. Did u do the front sub frame bushings. I ordered the rear and the pumpkin bushings, ground ship from California, 7 days. Install next week.
jamesmost
rear subframe and differental bushings replaced w/energy suspension, most noticable suspension upgrade q is hooking up like a beast it also seems to have raised up about 1/4-1/2 inch because of the lip on bushing which allows the drive shaft to line up better less of an angle my car feels amazing thanks for the help
