Though it doesn't list a source for rack overhaul, here's a thread from a search on rack overhaul..
How many miles does it have? Are you the DIY type?
I would get the rack overhauled then replace the rack bushings, new boots, and possibly new inner tie rod ends. Also, depending on mileage and condition, replace the outer tie rod ends. A front end alignment will be needed.
I've saved some money by using MOOG suspension parts where possible..
BE CAREFUL WITH POWER STEERING LINES as many are no longer available from the OEM parts suppliers.
post6115815.html?hilit=rack%20overhaul#p6115815
