95Q OEM part# tension rod bushings
kevindanielk
Car: 1995 Q45 Stock, except for the blues.
I need the dealer oem part number for the tension rod bushings, for my 95Q, with the larger diameter ones. I ordered some from Amazon and they sent me the smaller diameter ones that don't fit. I plan on ordering the ones from IOS but I'd rather have a part number on hand, when I call, in case their sales rep doesn't understand what part I need. Any help with that bushing number will be greatly appreciated.
rabsusa
Car: 1995 Silver mist Q45t 79 k miles
1994 Black Base 89 k miles - spares car(trans broke)
kevindanielk wrote:I need the dealer oem part number for the tension rod bushings, for my 95Q, with the larger diameter ones. I ordered some from Amazon and they sent me the smaller diameter ones that don't fit. I plan on ordering the ones from IOS but I'd rather have a part number on hand, when I call, in case their sales rep doesn't understand what part I need. Any help with that bushing number will be greatly appreciated.
with pics,,,,
post6012901.html?hilit=tension rod part#p6012901
rabs
kevindanielk
Thanks rabsusa, but I am looking for the Infiniti oem part number that I can use to order the oem tension bushings, from IOS or another Infiniti dealer. Any one else care to chime in? I can seem to only find the entire tension rod, listed online at dealer sites. I have a press, so I only need the bushings.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Should be the right part number: 54476-35F20- But thats for the JDM G50 Q45...
It used to be $25 in 2009!
kevindanielk
Thanks for that info Infinitiguy19. They seem to run about $30 now.
You wouldn't happen to know what the oem part number for the front left side upper link is, would you? :)
Infinitiguy19
54525-66U20-
kevindanielk
Thank you once again Infinitiguy19. You are a parts list knowledge house :)
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Or get the polyurethane ones for the Z32 from SPL Parts. A little harsher, but never need replacing.
Cecilia48
ImageThanks rabsusa.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Infinitiguy19 wrote:Should be the right part number: 54476-35F20- But thats for the JDM G50 Q45...
I have a pair of these given to me by a local member who said they didn't fit his 90Q. As I recall he said the bushings for the Q with active suspension ending up being the correct size. If Kevin can compare what he got from Amazon the center hole diameter on mine are 14mm. Hopefully they'll fit my 94Q when I need to change them out.
