95Q altinator 360k going bad ?? see symptoms
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
w/ a/c on kept getting low volt reading on my radar detector fluctuated 14.4 - below 12v.tcs/slip which is always lit on my car flickered.rpm fluctuated.this was in stop traffic 95 deg. ac crankin.shut a\c and smoothed outtraffic let up and when cruising no issues w/ ac on360k i know it needs changin anyway, have a factory reman in trunk.plugged it into trickle charger when got home and needle was at 1/2battery has 10k and 6 mos on it.
qship96
Car: 1996 Infiniti Q45
yeah,plan on replacing before it dies and takes out the battery or leaves you stranded-but just for kicks,check belt first to make sure it is tensioned properly!
Wow 360k on original alternator? and here I was thinking of replacing mine at 200k just for safety sake! guess I will hold off on that now!
DrewQ45
Car: 1990 Infiniti Q45
360K on anything is amazing. Whats the record mileage on a Q here?
jamesmost
factory rebuild installed today all good, bought it from a member for $80 w5k on it$200 labor
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
jamesmost wrote:factory rebuild installed today all good, bought it from a member for $80 w5k on it$200 labor
You did real good! Glad to hear that you're up and running. Did you find out what had failed on your alternator? Did you replace the belt?
jamesmost
no belts was just done, prob the regulator went according to the flucuationsthe old one looked nasty.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Very good james, got your voicemail.. This is probably the easiest repair you've had in recent history... knock on wood!
jamesmost
elwesso wrote:Very good james, got your voicemail.. This is probably the easiest repair you've had in recent history... knock on wood!
yep- my slow window up problem of the past couple of years has improved by 30% as well.
lino
How did you get it to improve?
carfrk666
Car: 1993 Infiniti Q45
1995 Nissan 240SX
replaced every mechanical part on the car thus making it new?
jamesmost
carfrk666 wrote:replaced every mechanical part on the car thus making it new?
Altinator - solved that problemwhen i changed the altinator on my benz it fixed the abs
Q451990
It's amazing what low or unstable voltage will do to electronics
