Agreed, DW in the past had a LOT of issues and personally I will not deal with them.NolimitZ32 wrote: ↑Thu Apr 05, 2018 8:47 am3 year warranty on injectors isn't going to do any good when you have to replace the engine, I AM NOT saying this WILL happen with DWs or any others just pointing out that you need to be mindful when leaning on such things as a 3 year INJECTOR warranty. DW, at least in the past have produced more than an allowable quantity of sub-par product, specifically sidefeed JECS based units, I have no experience with other brands. All that said DW is known for having great customer service and being proactive in resolving issues with their injectors but they wont replace an engine. My advice is spend the additional $200 and get some Nismo injectors, they are manufactured by JECS directly for NISMO, they are manufactured as 7400cc units not redrilled like DWs are (or at least used to be). Also what type of power are you chasing and what turbos are you running to warrant such big injectors?
Good stuff evildky, I forgot about the injector pulse part and how that's also a huge player in the injector game. When I had my work done the Subie injectors were judged just a tad too large at 850cc, and the 800's would work better for a short, correct-sized dosage as the valve opens.evildky wrote: ↑Thu Apr 05, 2018 9:13 amJust to ballpark the size question a bit. on a 6 cylinder, those 740's will supply enough fuel for over 700 WHP, if you run E85 closer to 500 WHP. 950's can support up to around 900 WHP, and if E85, closer to 700 WHP. So the question is what fuel are you running, and what kind of power are you aiming for? If you are sport 550 turbo's, the 740's are more than enough fuel even on E85. This math is all ballpark, you can look up and do the math yourself but it gets you in the neighborhood.
You want your injectors to be a little larger than you need for safety margin, but not a lot. The larger the injectors the shorter the injector pulse will be, ideally the injector pulse matches the time the intake valve spends open for the best chance to mix with the air completely.
