jessetang »
https://forums.nicoclub.com/jessetang-u32429.html
Mon Feb 08, 2010 10:41 am
There are two adjustment screws, one at the end of the headlight (towards outside of the car), the other is next to the water meter thing. The first one adjust from left to right, the other one adjust up and down.
The ghetto way to do it: get yourself to a wall with at least 40ft of ground between the car and the wall. Make sure the ground and the wall is perpendicular. Then turn your headlights on. You will see 2 marks on the wall by the lights. Adjust them until they are good.
P.S. Hids in older headlights will not have beam patterns properly anyways...
