95 vs 92 cars
datsunmotorsports
Car: 74 260Z , 71 240Z , 71 510 wagon , 68 Fairlady 2000, 82 Diesel Maxima
I have the chance to buy a second Q45. I have the 92 currently. I plan on buying the 95 and using the 92 for a few parts. The 95 looks a lot cleaner and has only 2 problems. The ECU and the stereo deck are missing on the 95. I have both of those from the 92. Now I also own a 92 SER and Nissan changed the SER over to OBDII in 94... Is the 95 Q45 OBDI like my 92 or OBDII. In more simpler terms will the ECU from my 92 work with the 95 Q45?
Ray
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
95 is OBD1. 96 was the first year of OBD2. I dont know if you can use the 92 ECU in the 95, but I think you can. I'm sure the experts will verify this.
Q451990
They may be cross compatible, but ECUs are fairly cheap... I would probably get the right one - or even better, see if Robert can program your 92 with the 95 program (plus cool modifications). As Lou mentioned, both are OBDI. As far as the stereo, I think the connectors are different. You could make a cheater harness, or just buy one from a 94-96 on eBay.
Heath
goody90q45
Car: 1992 Infiniti Q45 (sold)
datsunmotorsports wrote:.......The 95 looks a lot cleaner and has only 2 problems. The ECU and the stereo deck are missing on the 95.
I've been looking at the same Q (San Rafael?) but it's just a bit far away to pay for towing. I wish I owned a flat bed or big truck. You're getting a good deal if the engine and transmission are OK and if they're not there's a lot there in parts. Good luck.
DrewQ45
Car: 1990 Infiniti Q45
Q451990 wrote:could make a cheater harness, or just buy one from a 94-96 on eBay.
I have a 94' radio and climate control available on the parts forum if you end up needing one.
zerothread?id=237867
datsunmotorsports
That is the car in San Rafael. He says it runs well and he has service records.
getting a modded ECU would be nice if I had the extra cash afterward. The owner is considering a trade for my 92 SER which was bought specifically to make a turn around and get the cash needed to fix my current Q45. I just gotta drive up there.
Im hoping someone knows for sure I can plug mine in at least to test drive and or drive the car home and if it is good enough, to also smog the car for now.Ray
DrewQ45
datsunmotorsports wrote:Im hoping someone knows for sure I can plug mine in at least to test drive and or drive the car home and if it is good enough, to also smog the car for now.Ray
Yes, 90-95 ECUs will work for sure in a 95Q. The following thread will confirm.
zerothread?id=148562
Quote, originally posted by Q45denver »
elwesso wrote:Quote, originally posted by maxnix » So, by inference, Robert can reprogram the 1995 ECM also?
in about a month for $50 more or so
elwesso wrote:
Wes, when you get a chance could you list the ECU model numbers that will work with a 1995 Q with TCS . Is there a difference between the 1995 and the 1994 versions?
qsiguy
Car: 1994 Infiniti Q45 Turbo
FYI,My '94 Q has a '93 ECU and it works great.
datsunmotorsports
Thanks DrewQ45. That is great news. I have someone on the way to buy my SER so I hope to see about picking the new Q45 up if he hasnt sold it tomorrow.
Ray
